not a chopper but .......
Ok guys - been working on this in the background for the last couple of months -
I started out with the need to rebuild the stock dash for the vf750 - but didn't want to change the look - so I ended up designing and making anelectronic replacement -
the meters are all driven by dash stepper motors - as used in all the modern electronic dashed - with the displays using OLED white displays -
attached is a photo of the vf750 unit - excuse the overexposure - phone doesn't like the bright displays.
From there I decided how about other bikes where there is a desire to keep the original "gauges" but replace / upgrade the internals....
currently working on
modded cx500 - untertail exhaust + lots of changes
VF750f - restoring a basket case very nearly there
vf750S - just needs the paintwork done and some tyres
gathering parts for - moto guzzi bellagio lookalike
version based on cx500
others
cm250
others
cm250
Re: not a chopper but .......
So this led to the concept of a generic gauge -
it has two OLED displays -
these can be set as ODOMETER, TRIP, FUEL, TEMP, VOLTAGE (+gear) OIL PRESSURE
and one stepper driven needle -
this can be set to TACHO or SPEEDO-
All inputs are measured by the gauge -
there are some jumpers on the back to configure dipsplay coice -
there is a software (serial terminal via usb) that allows editing of settings -
wheel circumference - metric or imperial units , starting odometer reading.
the FUEL,TEMP,SPEED and TACHO displays are configurable throug this terminal - there is a start and end point and angles as well as the facility to correct gauge linearity -
This allows any existing gauge faceplate to be matched in the settings.
the base body size is 75mm - but comes in any size needed to fit the gauge as required.
the gauge incorporates LED lighting - as the top 3d printed layer is transclucent.
couple of shots a base gauge
others
cm250
others
cm250
So on to a setup to illustrate - ( i know its an ugly cx500 standard dash but ....)
below is shown a before and after of the good old standard CX dash -
reuses the faceplates and needles, buckets etc.
before
bits to go in - faceplates on
before
others
cm250
others
cm250
the working unit - set as odo/trip on the speedo and voltmeter / gear at top of tacho and fuel on the bottom.
i would expect this to be more applicable to the custom / deluxe gauges
and in particular to other bikes where an upgrade but original appearance might be sought - eg cb750s and goldwings
The gauges are not honda specific - they can be used on any brand
I need to do some document writing etc before they become available through the website and ebay - but just a heads up -
another option in the mix.
standard sizes will be to suit 3", 3 1/8, 3 3/8 , 4"
the tacho runs of the ignition -
the speedo uses a hall sensor -
oil pressure if desired - 150psi piezo pressure sensor (about $15 US)
temp and fuel senders as usual -
gear if required calculated on rpm/speed ratio
now has a clock option also
Rayman
Rayman
others
cm250
others
cm250
Ok -
so where to from here -
these will give you a possible option to run a new electronic gauge with some extra info / in the old gauge housing and faceplate so you can maintain your original
instrument look rather than some of the ugly Chinese dashes.
I'm looking to get a few gauges sets together for examples to show in the manual and for the marketing shots -
I'm not limited to honda - any brand is workable - particuarly looking for some Cb style gauges - (non working prefered as they can be turned into working
let me know thoughts / and if you have something that might suit.
Regards
Rayman
Regards
Rayman
others
cm250
others
cm250
Wow..! You've been a busy boy, Ray. Love what you've done to the CX dash clocks. Also looks good on the VF set.
Great stuff.
Great stuff.
Don't understand much of what you said, but has a lot of potential for old bikes gauges. Great work.
Here's a more standard set of clocks to give you an idea -
this a v45 magna set - odo / trip on the speedo -
volt / gear and a clock (new addition) on the tacho side.
Rayman
Rayman
others
cm250
others
cm250
What operates the speedo? Could a small digital display of speed and odometer be made to fit in a small space to mount in/on handlebar/handlebar mount?
speedo operates off a small hall sensor - I actually use the stock speedo cable drive - remove the cable - fit a magnet to the rotating blade and then use a 3d printed part like the original cable end to hold the small
hall sensor - and run the cable (3 wires) up to the speedo.
anything is possible - but if you just wanted small digital speedo - then this unit comes well respected.
https://www.dan-moto.com/DM_INT/index.p ... 4ee2db38b0
Its not worth me trying to compete in the arena with the Chinese aftermarkets - but for keeping the original look and gauge bodies I can do something.
Regards
Ray
Regards
Ray
others
cm250
others
cm250
Checked out the link. So what would the roughly ball park approximate cost be for just a speedo and odo in a supplied mini 60mm speedo case? I would prefer to run it off the rear wheel via a wire if possible. I may be asking the impossible, but thought I'd ask anyway. The bicycle speedos run off a small magnet on the brake rotor or rim.
