not a chopper but .......
Rayman
Post by Rayman » Tue May 16, 2017 1:40 pm
Ok guys - been working on this in the background for the last couple of months -
I started out with the need to rebuild the stock dash for the vf750 - but didn't want to change the look - so I ended up designing and making anelectronic replacement -
the meters are all driven by dash stepper motors - as used in all the modern electronic dashed - with the displays using OLED white displays -
attached is a photo of the vf750 unit - excuse the overexposure - phone doesn't like the bright displays.
From there I decided how about other bikes where there is a desire to keep the original "gauges" but replace / upgrade the internals....
currently working on
modded cx500 - untertail exhaust + lots of changes
VF750f - restoring a basket case very nearly there
vf750S - just needs the paintwork done and some tyres
gathering parts for - moto guzzi bellagio lookalike
version based on cx500
others
cm250
Rayman
Re: not a chopper but .......
Post by Rayman » Tue May 16, 2017 1:42 pm
So this led to the concept of a generic gauge -
it has two OLED displays -
these can be set as ODOMETER, TRIP, FUEL, TEMP, VOLTAGE (+gear) OIL PRESSURE
and one stepper driven needle -
this can be set to TACHO or SPEEDO-
All inputs are measured by the gauge -
there are some jumpers on the back to configure dipsplay coice -
there is a software (serial terminal via usb) that allows editing of settings -
wheel circumference - metric or imperial units , starting odometer reading.
the FUEL,TEMP,SPEED and TACHO displays are configurable throug this terminal - there is a start and end point and angles as well as the facility to correct gauge linearity -
This allows any existing gauge faceplate to be matched in the settings.
the base body size is 75mm - but comes in any size needed to fit the gauge as required.
the gauge incorporates LED lighting - as the top 3d printed layer is transclucent.
couple of shots a base gauge
others
cm250
Rayman
Post by Rayman » Tue May 16, 2017 1:52 pm
So on to a setup to illustrate - ( i know its an ugly cx500 standard dash but ....)
below is shown a before and after of the good old standard CX dash -
reuses the faceplates and needles, buckets etc.
before
bits to go in -
faceplates on
others
cm250
Rayman
Post by Rayman » Tue May 16, 2017 1:56 pm
the working unit - set as odo/trip on the speedo and voltmeter / gear at top of tacho and fuel on the bottom.
i would expect this to be more applicable to the custom / deluxe gauges
and in particular to other bikes where an upgrade but original appearance might be sought - eg cb750s and goldwings
The gauges are not honda specific - they can be used on any brand
I need to do some document writing etc before they become available through the website and ebay - but just a heads up -
another option in the mix.
standard sizes will be to suit 3", 3 1/8, 3 3/8 , 4"
the tacho runs of the ignition -
the speedo uses a hall sensor -
oil pressure if desired - 150psi piezo pressure sensor (about $15 US)
temp and fuel senders as usual -
gear if required calculated on rpm/speed ratio
now has a clock option also
Rayman
others
cm250
Rayman
Post by Rayman » Tue May 16, 2017 2:02 pm
Ok -
so where to from here -
these will give you a possible option to run a new electronic gauge with some extra info / in the old gauge housing and faceplate so you can maintain your original
instrument look rather than some of the ugly Chinese dashes.
I'm looking to get a few gauges sets together for examples to show in the manual and for the marketing shots -
I'm not limited to honda - any brand is workable - particuarly looking for some Cb style gauges - (non working prefered as they can be turned into working :))
let me know thoughts / and if you have something that might suit.
Regards
Rayman
others
cm250
Post by Bearcx » Sat May 20, 2017 11:15 pm
Wow..! You've been a busy boy, Ray. Love what you've done to the CX dash clocks. Also looks good on the VF set.
Great stuff.
Post by Prof » Mon May 22, 2017 11:17 pm
Don't understand much of what you said, but has a lot of potential for old bikes gauges. Great work.
Rayman
Post by Rayman » Mon Jun 05, 2017 2:51 pm
Here's a more standard set of clocks to give you an idea -
this a v45 magna set - odo / trip on the speedo -
volt / gear and a clock (new addition) on the tacho side.
Rayman
others
cm250
Post by Prof » Tue Jun 06, 2017 8:51 am
What operates the speedo? Could a small digital display of speed and odometer be made to fit in a small space to mount in/on handlebar/handlebar mount?
Rayman
Post by Rayman » Tue Jun 06, 2017 12:34 pm
speedo operates off a small hall sensor - I actually use the stock speedo cable drive - remove the cable - fit a magnet to the rotating blade and then use a 3d printed part like the original cable end to hold the small
hall sensor - and run the cable (3 wires) up to the speedo.
anything is possible - but if you just wanted small digital speedo - then this unit comes well respected.
https://www.dan-moto.com/DM_INT/index.p ... 4ee2db38b0
Its not worth me trying to compete in the arena with the Chinese aftermarkets - but for keeping the original look and gauge bodies I can do something.
Regards
Ray
others
cm250
Post by Prof » Fri Jun 09, 2017 10:07 am
Checked out the link. So what would the roughly ball park approximate cost be for just a speedo and odo in a supplied mini 60mm speedo case? I would prefer to run it off the rear wheel via a wire if possible. I may be asking the impossible, but thought I'd ask anyway. The bicycle speedos run off a small magnet on the brake rotor or rim.
