shockie spring compressor & home made battery
chopperal
Post by chopperal » Sun Oct 30, 2011 6:16 pm
Hi
I found these on Youtube and thought you might be interested
making a 12 volt bike battery
&feature=relmfu
al
tigerbob
Re: shockie spring compressor & home made battery
Post by tigerbob » Mon Oct 31, 2011 10:11 am
That battery one was interesting- thanks for sharing!
'94 Dyna Convertible
'71 T140v Bonneville
Post by Prof » Mon Oct 31, 2011 10:43 am
Here's the battery blurb...
Here's a battery for your motorcycle that weighs in at under 2 lbs! It's only 4 x 2.5 x 2 inches in size. It has approximately 200 cold cranking amps and 4.6Ah capacity.
This battery successfully cranked my 1200 Sportster 6 times in a row with almost no break or significant charge time (6 cycles of engine start followed by less than 10 seconds of run time, then shut down and repeat). The battery pack showed no sign of slowing down.
The down side? It's a bit expensive (expect to spend $150 - $200).
An R/C battery charger is recommended for initial charging. However, it's supposedly safe to use a 5A car charger with close monitoring (they charge fast - under an hour!). Thereafter, the motorcycle's charge system should be adequate. Do not use a trickle charger (Battery Tender) with A123 packs.
Additionally, these batteries are resistant but not impervious to imbalance. I did not include balance leads on my packs, but they may be worth using in order to perfectly charge the pack from time to time.
Here are the parts sources I promised:
26650 A123 cells, 145mm shrink wrap -- battlepack.com
Dewalt DC9280 or DC9360 battery packs are another source of batteries
Forklift connectors (6382PT) -- Amazon (or McMaster 7043K91)
Hyperion battery bars and balance connectors -- aircraft-world.com
6AWG welding cable -- www.mcmaster.com
6AWG ring terminals - Home Depot
MegaPower 930SR 1S~12S Li-po/A123 Charger + LCB12S -- aero-nuts.com
Post by Bacca » Tue Nov 01, 2011 6:39 pm
We all have one of them mills in our shed too :D
Thanks for posting
Made em direct on here for ya
Post by Prof » Tue Nov 01, 2011 9:02 pm
Thanks for that Bacca.
I've made one that bolts onto the vice. In place of the CNC'c hole I welded up an angle iron square and ran a bolt in from each of two sides to catch on the outer ring of the shocker. Instead of pulling up with threads, I hinged it so I can lever it down and hold the lever under my armpit and pull out the retaining ring. Just needed a welder and drill. Important to keep your pinkies out of the set up when removing the retaining clips or you'l never play your violin again!!!
Return to “Tools...”
