the winter rebuild of this...
1st i'll bung a load of pics up with brief descriptions, (not the best quality, i took them on my phone), then kinda explain things from there..
after strip-down, this was the 1st idea.
suzuki jeep back wheel, engine spun 90', shaft drive off the gearbox output shaft, same tank, front end from bits that were lying around.
to get that rake on the front end i'd need raked yokes. cut by hand with a hacksaw, tidied up with files. they're finished now, with big radiused curved edges, to give an 'organic' smooth look. more pics later.
this was the first drive idea, the hub cut out of a Z1000ST back wheel, to fix to the jeep wheel.
then i fell off my other bike, that i'd put the single-sided back end in, so the plan changed (briefly) to this, so i could use some of the bits... you can
see the rake in the (unfinished) yokes, also the downdraught weber carb and the wishbone front end. the forks are just the legs, with the sliders taken off and axle supports welded on the bottoms
then i was lured into the dark world of superchargers!!
so i got a couple of cam pulleys fron a nissan skyline and a big air filter for the weber and a lump of HE30 ally off e-bay, and a new supercharger off an amazing bike builder over here called 'twizzle'.
i really wasn't happy that i'd turned the engine back round the 'right' way, so i had another re-design. bought an Aston Martin 3-piece bolt together rim off e-bay, so i can widen it to take a 360/30-18 tyre. then i went to the scrap yard and bought the rear sub frame from a citroen zantia, so i can use the 'uppy-downy' suspension, (variable ride height and no side stand, it just drops down onto a plate under the sump when i turn the engine off) i'll run it from an electric power steering pump that'll be hidden away somwhere...
then it was time to hit the lathe, to do the pulley mounts, and start the wacky final drive set up.
next i tacked up the exhaust, made out of 3 old systems i had lying about. it will be heat-wrapped in black heatproof webbing. dont forget, what was the front of the engine is now the left side!!
that brings us pretty much up to date, i'll bung some background up soon, it seems to go in 'fits and starts' coz i've got two othe projects on the go as well. i'll bung some more up soon, i hope you enjoy the build, comments please!!!
