Steering head bearings
steve
Post by steve » Wed Dec 30, 2015 9:26 am
Hello all
I have an old bike frame that runs conventional ball bearings in the steering head. These are ball bearings with a inner and outer race as part of the bearing.
The original bearings are SKF# 7206 and SKF 7205.
I am considering putting in taper roller bearings.
As a result of this I have a few questions.
Is there any reason this is not a good idea?
Are they generally a drop in solution if I can get the correct sizes or do I need additional spacers between them like when a wheel has tapper roller bearings?
Can anyone recommend a good source of technical information if this question can't be answered here.
Thanks
Steve
Re: Steering head bearings
Post by Prof » Wed Dec 30, 2015 2:54 pm
Contact your local bearing supplier. Give them stock bearing numbers and ask them the same questions. From my experience the tapered rollers take up no more space than a couple of mils which is within your headstem's capabilities. However your bearing guys should be able to tell you that.
Tapered rollers take a lot more strain than balls and are particularly beneficial with extra rake. Make sure you grease them well. This can be done by hand... just a bit messy.
