Tank sealant. Recommendations?
Chat about choppers here. Any posts considered by forum administrators to be used by businesses as unpaid advertising will be promptly removed...
Post by Bearcx » Fri Apr 24, 2015 12:06 pm
Hey everyone.
Been a while since I've touched the CX, and the fuel tank has an external coating of surface rust. As there is no fuel tap etc, the inside has obviously copped the same abuse from the weather. So, my question is, have you used a tank sealer such as KBS or POR15?
I read about Redkote on the 'net, it's a single chemical, (not a 3part). Any advice?
Cheers.
Hustler
Interests: Bikes, boats, cars
Re: Tank sealant. Recommendations?
Post by Hustler » Fri Apr 24, 2015 7:54 pm
I have used por15 a couple of times, works well but takes abit of time, cheers
Post by Bearcx » Fri Apr 24, 2015 10:07 pm
Thanks Hustler. Might just add that the tank has been widened from stock and welded in several different areas. Another reason for me wanting to make sure its sealed inside.
Post by Prof » Fri Apr 24, 2015 11:11 pm
Check with your auto paint supplier. There is an alternative to POR15 which is apparently as good, but much cheaper. KBS does ring a bell, but not sure. Both products have a metal cleaner/primer as part of the process.
Post by Bearcx » Sun Apr 26, 2015 8:54 pm
Cheers guys.
Return to “Chopper Chat (includes how to post photos)”
