engine number of shovel
ran
Post by ran » Mon Mar 19, 2012 10:36 am
ok..i have a 77 shovel..but engine is not original...and when i look up the numbers it says its a sporty engine...but its not....so am i looking at wrong thing....engine number starts with 4A , which is code for a 1000 sporty....? last 2 digits are H4 which means its a 74....so..anyone got more info for me....did sporty engines in 74 have separate gearbox?...i didnt think so....my engine is def a stand alone until...no chopped, not a sporty engine....cheers
KBG
Re: engine number of shovel
Post by KBG » Mon Mar 19, 2012 3:49 pm
Sounds like it may have been re stamped, Ive had a couple with sus numbers one pan had hummer #s.
Got any pics of them? harley has a certain type of stamp and most restamps don't use Harley type numbers.
some meaningless dribble
Post by Neo Dutch » Mon Mar 19, 2012 6:32 pm
4A is for XLCH's specifically. If your bike is an FL the numbers should start with 1A or 2A or if it's an FX 2C or 9D. There are other starting codes for the more obscure BT's.
If it was me, I'd get this sorted before you dump to much money into this thing. One switched-on copper and you won't be collecting $200.
ran
Post by ran » Mon Mar 19, 2012 7:01 pm
It's been regoed thru three different owners like this...I've got all the old rego and rwc papers...this number is on the right side at front. I've been told another number is on primary side but I cannot see it
Post by Brassy » Mon Mar 19, 2012 7:08 pm
whats the frame number a shovelhead one it may be registered under the frame numbers !
ran
Post by ran » Mon Mar 19, 2012 7:38 pm
On rego papers it has frame and eng numbers listed
KBG
Post by KBG » Mon Mar 19, 2012 9:06 pm
Just because its regoed with those numbers does'nt make them correct.
For peace of mind I would change cases, or what ever to get the right numbers.
But you may never have any dramas.
Post by Neo Dutch » Mon Mar 19, 2012 9:07 pm
There are "belly" numbers on the bottom of each case. These will be the same, but all they identify is that the cases were assembled together at the factory.
