Points adjustment...
Post by Prof » Mon May 01, 2006 8:23 pm
When adjusting Harley points, check clearances at both cam lobes. If they are not with in about 3thou of each other, loosen points cam bolt and retighten as points cam can shift slightly on shaft.
