1985 FXST Softail standard rake
This forum applies to Harleys.
Butcher
Post by Butcher » Tue Apr 19, 2016 12:44 pm
I've been trawling the net but cannot find what the manufacturer's specification is for the rake of a 1985 softail. Any ideas how I can find out what rake these machines were made with ?
tigerbob
Re: 1985 FXST Softail standard rake
Post by tigerbob » Tue Apr 19, 2016 2:39 pm
I believe they are 32° - which is also the same for Wide Glide...I think
I'm sure someone can confirm or deny?
'94 Dyna Convertible
'73 TR6 Tiger - chopper under construction
'71 T140v Bonneville
Post by Silent Grey Fellow » Mon Apr 25, 2016 10:52 pm
tigerbob wrote:I believe they are 32° - which is also the same for Wide Glide...I think
Your close tigerbob but it is in fact 34 degrees for both the softail and the wide glide all the way thru the Evolution engine models 1984 - 1999
Butcher
Post by Butcher » Tue Apr 26, 2016 7:50 am
Thanks fellas - appreciate it
Butcher
Post by Butcher » Sun May 15, 2016 1:36 pm
OK - so now it is time to put some rake on my bike.
Don't want to cut the frame and certainly not going to use raked triple trees. The Prof advises that 3 degree rake steering head races/cups or whatever they are called is the next best option.
I rang EasyR in QLD and they sell for like $240 but have none in stock (Vulcan brand) and they are already on back order in the USA (6 months wait). So trawling the net I find
Racked fork cup set $100
Racked fork cup set with stop
Then from another supplier these
Note those that suit a 1985 FSXT - the second from the top left and the bottom two. These are between $40 and $50 odd dollars.
I am also told that I should have a "guide tool" which isn't available with these products (from the photos)
So a) I don't know what to buy
and b) I'd rather buy them here in Oz as if I get the wrong set - its a pain to replace.
Rego is up in July so I need to be finished by then
Any advice / help / thoughts ??
Return to “Fits 'n Bits; Harley...”
