Concentric carbies are fastened to manifolds using rubber washers. These compress after a while and can result in air leaks.
Replace manifold "o" rings with gaskets, leave out rubber washers and add extra steel washers to space nuts out from steps in bolts.
Check slides to make sure they aren't binding. If one does, ease off tension on maniflod bolts until it is free.
Concentric carbs
Concentric carbs
