Problem solved
Problem solved
Hi guys, I've lost my key, can I just change the ignition switch?
2002 TA SHADOW, it may be small, but it's my first I'm I've ever worked on myself, *#@** the factory's, do it in your garage!
Re: Problem solved
go check with ya honda shop mate. they might have a number/code and will fit.
if you change the whole switch, unless its from same model chances are you're gonna have to chop into the wiring....if youre feeling brave, hook in.......but if not, it just unplugs under the tank/or in head light, plug in a same model replacement.
Re: Problem solved
Thanks C, found the key in the bin, must of swept it it there whilst making some new seat mounts, mustbtie it to a car hubcaps or something...
