This forum applies to Hondas.
Right....I've got a set of valve guides, 4 are 46mm long & 4 are 49mm long, anyone know which is inlet & which is exhaust? Extensive web searching has yielded no result
Cant help with actual info needed as ive not got any Honda four stuff anymore...but i can recommend you google 'Satanic mechanic'
was an invaluable source of schematics, performance mod info and part number info etc....part numbers match with description-ya found your info.
