voltage regulator/rectifier
This forum applies to Hondas.
podgy
Post by podgy » Sat May 27, 2006 9:27 am
just some info about replacing the satndard voltage regulator and rectifier that are seperate items on a 750 4,the unit from a dohc model 1980 and up will do the job of both as its a combined unit and being solid state is less likely to give problems,the part number is sh236-12,these can be got on ebay for abot 75 usd including frieght,thats new if u try to get one here new u would be looking at $170 aud at least,if the wreckers are not aware of it u might be able to pick up a second hand one cheap.
the best way to tell if its what u want is look for the 3 yellow wires and a green,a white,a black.
hope that helps somebody
cheers podgy
Post by Cromag » Sat May 27, 2006 2:20 pm
So what goes where? ....3 yellows to alt, green to alt, white to alt, black to ? battery is it.......if it is iam getting better at this stuff, ha ha ha.
podgy
where the wires go
Post by podgy » Sat May 27, 2006 7:10 pm
if u go to
www.hondachopper.com
and look in the garage section u will find an article on how to wire the thing up
cheers podgy
