Coil leads...
This forum applies to Hondas.
Coil leads...
Post by Prof » Thu May 04, 2006 7:11 pm
Coils from 1981 DOHC Honda has removable high tension leads and is suitable for CB's
SimonJ18
Post by SimonJ18 » Fri Sep 08, 2006 12:41 am
You can also use Honda Goldwing coils on your Honda Four, they also contain removable ignition leads, anything can be used really.. just make sure the coils that you replace your stock ones with are rated with the same Ohms. Removable leads are the way to go :)
